Welcome to Forma for Construction Ideas! View the Forma for Construction Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
Forms template builder: additional custom fields
I would like to suggest a new feature to the form template builder:
  • Custom fields to the form template builder. The location field can be linked to the project's locations.
  • For example, in public works projects, we are required to record the subcontractor's timesheet (start time, end time, etc.) so that it can be compared to their certified payroll, ensuring they are complying with prevailing wages. It is important to match their records with ours before they get paid. The GC's admin staff reviews all these records.
  • The GC's on-site supervisor maintains these records.
  • By having custom fields on any form created in Autodesk Build, we can run reports and data analysis.
3 Comments
ilige_akikiAYR75
This is exactly what I was looking for as well. Thank you for posting it.
I voted for it, hopefully the Autodesk dev. team will take it into consideration.
This custom fields option will also allow us to add visitors with their : name, time arrival/leave, notes...
I will also add that the custom fields option would be very useful in the materials and equipment sections. This would allow us to have more flexibility and leverage these built-in tools instead of having to create separate sections with questions.
RobinBenjamin317
Community Visitor
We create many projects in Autodesk, and we have created custom templates under the issues tab.  My inspector commonly finds new issues he would like the admins to add to his custom list of issue templates but when we do so, we have to first, add it to our master job template so future projects reflect this new custom template in our library of custom issue templates, but we then also have to pull up every project already programmed and actively running and go to create template to add the new issue template individually for every active job.  This is not only time consuming given the volume of jobs we have ongoing but also leave room for error - missing a job folder to upload to then the inspector is in wait pending the programming of this missed job.   There should be a way to create a new issue template in the master job programming but then a way to program the system to also add the newly created custom issue template to all active jobs on our account.  This is causing us to constantly have to halt work in Autodesk in the field to go in and add the new issue template in the job missed before the inspector can proceed.  There are similar constraints with other areas in Autodesk where updates need to be provided across several jobs, but we are having to manually go in and fix individually.
andi.reeder7PTHJ
Customers would like the ability to add custom statuses in the Forms module.
