Welcome to Forma for Construction Ideas! View the Forma for Construction Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
Forms - Table or a matrix
In Forms it would be really useful to have a table or a matrix in the template builder. When you are setting up in the template builder you could decide the columns and then add rows when filling out, this is similar how the daily report log works. Maybe also you could choose another option which would be to have fixed columns and rows which you then fill in selected fields.
This request came up originally in regards to commissioning, when we were setting up templates for test reports.
10 Comments
emilio.mercado
Status changed to: Accepted
Thanks for the suggestion. The ability to add a table with custom columns is on our short-term roadmap - and we're collecting additional requests for options, like the ability to set a fixed set of rows.
Worklog section is good but enough. The columns are not customizable and if you have a one worklog section in a form template you cannot have a second one. Would love to see a feature release where new sections can have tables and matrix with customizable columns.
buildintel
There are so many different sorts of commissioning results, @emilio.mercado I hope this new tool is up for the tas
@Dyrmundur_Helgi I dislike this functionality as it looks like going backwards in tech but it often works for complicated commissioning result pages. When you create a new Template, go via "Upload an existing PDF form". Give it a try
@buildintel Unfortunately uploading an existing PDF form is not the same as the template builder in ACC. For example use of data in dashboards such insight builder is almost impossible if the form is not made with template builder.
buildintel
@behnam_vafaei_newcold oh yeah, agreed. Pdf builder is a suprise that it still exists. It has no way to regulate internal data. His only alternative at the moment is for people to use real paper on site to collect the results and then upload a pdf on the Form. This is even worse option I find.
If the new product Emilio mentioned comes in quickly and is up for the task, all is solved
Dyrmundur_Helgi
@buildintel we have been using the Smart PDF and it works well in practice but to create and change the PDF form template takes ages. Not practical and people tend to go back to old ways, using Excel or Word. Then yes gathering and analysing the data is harder with the Smart PDF as @behnam_vafaei_newcold mentioned.
Essential feature. Please priorise
emilio.mercado
We've added the ability to set up tables in Native form templates
https://help.autodesk.com/view/BUILD/ENU/?guid=Forms_Section_Table
We've also started introducing some basic calculations
https://help.autodesk.com/view/BUILD/ENU/?guid=Forms_Table_Calculations
And the data is available via Data Connector and API
https://aps.autodesk.com/blog/forms-template-layout-and-custom-table-api-are-released
Dyrmundur_Helgi
Thank you very much @emilio.mercado this feature is great! Very happy with this improvement.
If I can give you one feedback: we encountered the maximum 15 columns and found that it is not enough in many cases, is that something being looked at? If it would be stretched to 30 columns that would be sufficient for (almost) every case, for us at least.
