Welcome to Forma for Construction Ideas! View the Forma for Construction Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
Feature Enhancement Request: Attachment Data Type in Table Section
Description
I would like to suggest a feature enhancement for Autodesk Forma Build Forms.
Currently, the Table section in Forms provides several data types, but an Attachment/File data type is not available. Adding an Attachment data type within a table would make it easier to capture and associate supporting documents, images, or files with individual table rows.
Proposed Enhancement
Add an Attachment/File data type as an available column type within the Table section of Forms.
For example, a table could contain:
Item Description Status Attachment
Inspection Item 1Concrete workCompleted📎 Photo/Document
Inspection Item 2Electrical workPending📎 Photo/Document
Inspection Item 3Finishing workCompleted📎 Photo/Document
Each row should allow users to upload or attach one or more files independently.
Key Benefits
  • Allows supporting documents or photos to be associated directly with the relevant table row.
  • Reduces the need for separate attachment fields outside the table.
  • Improves traceability between an item and its supporting evidence.
  • Makes inspection, quality-control, punch-list, and documentation workflows more efficient.
  • Reduces ambiguity when multiple items require different supporting files.
Suggested Functionality
The Attachment data type could support:
  • Uploading photos, PDFs, and other supported file formats.
  • One or multiple attachments per table row.
  • Previewing or downloading attachments.
  • Removing or replacing attachments.
  • Applying the same attachment permissions and storage behavior already available in Forms.
  • Retaining attachments when the form is submitted and available when reviewing the form response.
Example Use Case
For a construction inspection form, a table may contain multiple inspection items. Each item may require photographic evidence.
Instead of having a single attachment field at the end of the form, users could attach the relevant photo directly to the corresponding inspection item.
Requested enhancement:
Please consider adding Attachment/File as a supported Data Type within the Table section of Forms in Autodesk Forma Build.
@RakeshR @vaishnavi_g
1 Comment
vinodk_yadavR5T4N
Community Visitor
Good for everyday work and reliable performance.
