Welcome to Forma for Construction Ideas! View the Forma for Construction Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
Enable Replacing Naming Standards for Existing Directories that already contains files
Currently, ACC only allows you to remove a naming standard from a folder. However, it is not possible to assign a new naming standard to a directory that already contains files.
In project work, it often happens that a naming convention changes slightly and existing files need to be renamed to comply with the updated standard. At the moment, this process in ACC is very time-consuming and inefficient:
  • A new empty folder has to be created
  • All existing files must be manually moved into this new folder
  • The files then need to be revalidated against the new naming standard
Proposed Improvement:
It would be extremely helpful if ACC allowed users to directly replace or update the naming standard of a folder, even when files are already stored within it.
This feature would:
  • Save significant time during project work
  • Reduce manual effort and the risk of errors
  • Improve workflow efficiency for teams handling frequent naming standard updates
7 Comments
melissajohnsonS8S2W
This would be incredibly helpful for when clients have changes. Less admin, less costs.
YES PLEASE. and add to this the ability to assign Naming Standards to Project Template folder structures
rick_notari
I believe this is being considered, I remember it spoken about at AU 2024 in one of the ACC roadmap workshops.
lucija.resetar
Need this, would save hours jobs, as well remove/change existing dropdown options
Oh yes please ... its really time consuming to do this manually. ACC is really lacking basic and creates hours of extra work for us Admins.
anna_wahlsten
yes please! This is a huge and urgent issue on multiple projects, especially as the design changes design stages or even hands.
nicoletta_aleksic
This would be really helpful. Especially imagine having projects that have a duration of 5 years or so. It is unrealistic to think nothing would ever change in attributes. Not only naming standard but also attributes that you can check as 'required' on a folder.
