Welcome to Forma for Construction Ideas! View the Forma for Construction Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
DWG compare tool improvements
It's ridiculous the way compare tool for dwg files in ACC works.
1) If we are comparing two files that are in the same "place" I want them to align, not to manually have to move them on top of each other...
2) Compare should work the same way other compare tools works and recognize elements that are in the same place (same everything) and just ignore them from compare. I want focus to be only on the diferences (what was removed and what is added).
3) As a bonus, I want that compare to be able to be done globally or using only some layers. Right now it is even ignoring layers that were frozen when one of the the file version was uploaded and as such is giving a wrong result...
PS: I know that we should make one ideia per ideia, but in this case just fix them all at the same time and ASAP because they are all fundamental. Thank you!
