Welcome to Forma for Construction Ideas! View the Forma for Construction Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
Desktop Connector - Selected Projects
I understand the desire to conserve local file space, which is one reason the desktop connector has moved to select only 80 projects to keep locally. The issue our firm will see with this switch is that we have employees who work on over 100 projects within a short period. Having to select which projects to sync locally can cause confusion and result in the BIM Managers having to remind and troubleshoot visibility problems. If there was an option for optimizing storage, which would enable the project selection or an override to select all projects, I think this would help many firms that will be experiencing the same problem we will.
3 Comments
ASanchezDES
As a BIM Manager, I typically open multiple projects each day. The current limit of 80 projects means I often have to spend unnecessary time deciding which projects to unselect.
lweaver
Observer
Totally agree.  This limit of 80 makes using this inefficient and cumbersome.  Limit needs to be raised to make this a truly usable solution for most companies.
bfischer
FYI don't accidently delete your root folder as you will delete everything downstream and really cause pain for your organization. Vote up this one: https://forums.autodesk.com/t5/acc-ideas/fully-restore-folders-deleted-via-desktop-connector/idc-p/1...
