We're working on a project that spans many miles and will have plan sets released to us periodically. In lieu of submitting the same submittal 17 times (for each segment), we're looking to simply check boxes as part of the initial submittal process. Just need to add an option for a plan segment, and ability for the admin to customize what those are, similar to the spec packages now. Then during the submittal process, you can click a drop down with all the plan segments, and you can select which ones this submittal is applicable to. Or simply make it so I can modify the "Packages" section to be able to select multiple.
