Welcome to Forma for Construction Ideas! View the Forma for Construction Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
Automate the "description" field values in ACC Docs when uploading documents to streamline user workflow.
Upon document upload, automate the generation of a brief description based on file content or metadata.
Users can quickly identify uploaded documents without manual input through filtering metadata by using the Attributes from the Search Function, saving time and effort.
Example: My Native Revit Sheet is named "FRA01_ENER_XX_01_SP_AR_0001-GroundFloorElectrical"
when uploading to ACC Docs using Enforced Naming Convention, the Sheet should be split according to the enforced Attributes FRA01, ENER, XX, 01, SP, AR, 0001, however the "GroundFloorElectrical" is automatically eliminated from appearing in the Description Attribute and then needs to be manually added to the Description.
In use cases where we have hundreds of plans, manually adding ACC descriptions to all of these plans is very resource consuming.
Using the search function provided by ACC is also not ideal, as if I would like to identify all floor plans containing the string "Floor", there would be no results pinged back, unless this value is written in the Description field.
The benefit of automating such function is to reduce manual data entry and to improve document organisation.
Implementing this feature would significantly enhance user experience with ACC Docs.
32 Comments
Admin-BGL
Please can we add this, thank you
Chris_D_UK
Yes yes yes, the countless HOURS we waste manually doing this, when Revit knows the Sheet Name but won't talk to ACC - this is basic stuff!
Chris_D_UK
We also need the Revision field to be recognised too of course, such as in this example made using the PDF Export feature in Revit.
BCW-FEA-B1-00-DD-A-6221_RevC1_Partition Head to Composite Slab
daniel.taylorC2FLJ
Is it my imagination or did we not have this feature in BIM360? I seem to remember uploading to there and it could search for a sheet area and pick up the text data? Either way we definitely need it for ACC, I was surprised I couldn't do it!
MiWolff
One might as well ask for dealing with dwg layer descriptions within apps other than AutoCAD.
0205521_2
I've searched in BIM360 API and haven't found any reference to automate description field, it seems that we can only automate custom attributes.
We need this feature ASAP, having to edit description field for every file submitted is a complete waste of time.
postrovsky
There is workaround for this.
1. Abandon Description and create new attribute "Title".
2. Add the "Title" into Naming standard as accompanying attribute.
3. When uploading a file named as FRA01_ENER_XX_01_SP_AR_0001-GroundFloorElectrical where red text fitting mandatory naming convention, the blue text will be automatically filled in the "Title".
The disadvantage is that Title cannot be shown in Reviews and is not transferred while bridging the projects.
So I vote for the proposal anyway.
derek_o
@postrovsky I'll give this a go!
derek_o
@postrovsky just trying this.
What is don't understand is this 'the blue text will be automatically filled in the "Title".
As I've found the blue text disappears. Are you defining any mapping or condition that makes the remaining text enter the 'title' attribute anywhere?
postrovsky
@derek_o sorry, I misguided you. The attribute can only be populated if included in the "Naming convention", not the "Related attributes". Still you can include Title in the naming convention and then crop it by moving into a separate folder with another shorter naming standard. However, this approach doesn't seem to be feasible.2024-10-14 14_59_06-Files - Autodesk Docs.png
V.Kavaliou
I'm totally support this proposal. It's necessary that "Description" field can be used as part of Name Convention. Also i agree that attribute revision is needed.
Or another solution:  "Transmittal" und "Review" views must have a possibility to be customized. So that all custom attributes can be added to a transmittal or review view
daniel_osuala
Community Visitor
100% in support. Currently causing us issues on a project.
friction0802
Observer
Totally support this! Endless hours wasted by the team doing this exercise of manual entry.
Renata_Rogic01
Yes, we need this!! Thank you!
ycheungGQF7P
Fully support this. Or allow an export/import function on the description field would be great.
Renata_Rogic01
There is excel template to import and export 'Issues' on ACC. You can literally fill in excel file, upload to ACC and ACC is gonna create all issues listed in excel template.
It would be great if we had this template for other parts of ACC, 'Files' in particularly. Otherwise, we have a lot of manual work for 'Description' field. Yes, now there is 'Extract pages and attributes' tool in 'Files' which covers every single attribute except 'Description'.
Please plan for mass upload and mass edit tools like you already created for 'Issues'
daniel.hoogeveenHUJEK
It should also be mandatory to add the description at the time of upload when a naming standard has been implemented.
postrovsky
Another frustrating issue is that the Description field is the only attribute that is not accessible through the API.
@postrovsky  I didnt know this until now, and thats simply not good enough from ACC. It (description) along with the file name should be the first details off the rank to be available to the API
daniel.taylorC2FLJ
I hope this can be fixed soon, it is such a time-wasting exercise for everyone!
