Welcome to Forma for Construction Ideas! View the Forma for Construction Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
Aufgaben zentral im HUB verwalten
Für eine standartisierung von Projekten und einem zentralen Aufgabenmanagement wäre es gut, wenn die Aufgabenkategorien analog zu den Formularen für den gesamten HUB verwaltet werden können. Dies würde die Administration und Pflege von Projekten vereinfachen. So dass Benutzerdefinierte Felder, Aufgabenkategorien und Aufgabentypen für alle Projekte verteilt werden können, ggf. auch mit Vorlagen.
3 Comments
buildintel
Not sure the translation is 100% but if I'm understanding correctly, you want your Issue types to be saved in a Project Template so you so not need to recreate on each project.
That should be possible. Have you tried via a project template?
s.helfer
Thank you for your response. Indeed, the idea is to have issue types, categories, and custom fields managed centrally in a hub-like library, similar to how forms are managed in the Autodesk Construction Cloud (ACC). This would allow for a more streamlined and standardized approach across multiple projects.
While using a project template is a step in the right direction, the current process requires managing tasks individually for each project after creation. This leads to significant administrative effort whenever there is an update or adjustment to the company standard, as changes need to be manually applied to each project.
Having a centralized hub-library for these elements would further enhance efficiency and consistency. It would allow for easier updates and ensure that all projects adhere to company-wide standards without the need to recreate or manually adjust issue types for each project.
buildintel
My understanding is that Account Administration is being developed by Autodesk to expand more Issue information into the project template. So your wish might not be far from being implemented.
