Using Assets to track procurement, delivery, receipt, shake-out, installation, and commissioning, and using the References is great to have all forms, issues, and documents in one spot, but the inability to export an asset BY the asset and retain all the references is a major issue.
This is a huge duplication of work as a separate folder will need to be created and maintained outside of Assets to pull all related documents into Files so you can export it as an as-built.
Handover is not an option for this in Assets as it exports all references into folders that have no flow and require admin work to create a structure that makes sense.
It would be good if either Handover or As-Builts can export from the Assets module and is smart enough to retain all references into one single folder for Bridge or download to the end-user.
Hard to sell Assets as a single-source of truth if you have to maintain records outside of it as well in order to keep all information intact.
