Welcome to Forma for Construction Ideas! View the Forma for Construction Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
Add Forecast Adjustment Notes and Forecast Adjustment Reporting to Cost Management
Autodesk Cost Management needs a better way to support cost-to-complete meetings.
Customers need the ability to add a note directly to each forecast adjustment. The adjustment amount alone is not enough. Teams need to document why the forecast changed, what risk or issue caused it, and what action may be needed.
Autodesk should also add a standard report that shows the budget, current forecast, forecast adjustments, and forecast adjustment notes in one view.
This report should include:
  • Cost code / budget line
  • Revised budget
  • Committed cost
  • Actual cost
  • Current forecast
  • Forecast adjustment amount
  • Forecast adjustment note
  • Variance
  • Last updated by
  • Last updated date
This is critical for monthly cost-to-complete reviews. Without notes and a report, teams are forced to track explanations in Excel or separate meeting documents, which defeats the purpose of using Cost Management as the source of truth.
Priority: High
6 Comments
ian_turner
Status changed to: Gathering Support
Hello @kreidW7HWN
Does this notes field not help, available in the flyout when you select the forecast adjustment?
kreidW7HWN
It helps in the program yes, but when PM's sit down with leadership a report is usually generated / created showing adjustments per line item and the description. And while in that meeting, it's very helpful for the PM if their notes can be available with them not just the name of the adjustment.
ian_turner
Understood, just wanted to make sure you were aware we do have comments available?
So the request is just for the report, correct?
kreidW7HWN
Yes please, and it would be awesome to have the report include the notes section that you mentioned.
Pm's would love this report, even if it was limited to Excel. Thank you!
ian_turner
Status changed to: Accepted
ian_turner
