Welcome to Forma for Construction Ideas! View the Forma for Construction Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
ACC Model Coordination - Allow utilization of Issue Templates When Creating an issue from a clash
Users should be able to utilize Issue Templates when creating an issue from a clash.
We are utilizing custom fields and specific groups of watchers for different areas in a project and want an easy way to apply these values to clashes as we create them without having to fill them in manually for each clash.
I created Issue templates for each area assuming I would be able to utilize them when we created clashes only to find out that they do not apply.  😞
I could see this working as follows:
Method One:
  1. User selects Create Issue.
  2. User places pin.
  3. First selection in the properties window allows you to select and apply template properties to the clash.
Method Two:
  2. User places pin.
  3. A small window appears that allows you to select a template (or none).
  4. Properties window appears.
6 Comments
This would be an incredible time-saving enhancement. HVAC clashes would be assigned to a specific detailer role with a specific amount of time to fix it, etc.
jhijlkema
This feature partially exists in the Coordination Add In for Navisworks. You can create an issue through a clash and then select a template. However, this is not the case when you create an issue by clicking on a model item.
@jhijlkema That then breaks the connected workflow of the geometry being highlighted in Revit too
jhijlkema
@andrell.laniewicz Yeah you're right. So the more reason to fix this 🙂
Susana_Duarte_LMSI
@kimberly_fuhrman-jones , I think this is implemented the last time I used... We select the clashes, click to create an issue, select the template if we want or just the type and then place the pin in the model element we want.
@liam_murrayJZD7U , see Susana's note above.
