I was checking Autodesk Forma capabilities and, at certain moment, wondered if I could upload my proposal to a folder in Autodesk Docs to start a new workflow.
Does someone knows if it's possible to do that? If not, will it be available soon?
Solved by khushal_adlakha. Go to Solution.
Hi Lucas, thanks for your query.
This is a very relevant use case that we are currently planning for. Would you be available for a call discuss this topic further?
Thanks for your fast reply, Khushal.
Yes, I'm available to a further call to discuss this topic. I'm not a developer but I'd like to be aware of the next steps.
Thanks again.
