Hi I am trying to get the roofs, walls and windows constructions list. I also need the window-to-wall ratio. How can I do that from the forma API ?
Solved by mjovic. Go to Solution.
Solved by hakon.matland. Go to Solution.
Hi @mjovic .
It is currently not possible to retrieve the input parameters of the rapid operational energy analysis through our APIs.
To further understand what you'd like to do: Is it the parameters of the rapid operational energy analysis in particular you are interested in, or that type of details in general?
As an example the embodied carbon analysis (technical preview) has similar configuration, but on a per building level.
Those are not exposed through APIs either, but is something we know about other use cases for as well.
Thank you for your answer. We are analyzing the building from the energy point of view. In that case we need the data to set them as the initial values in our calculations. For now I can just hardcode that data but in the future would be good for us if we can have the real data from the API.
