Message 1 of 17
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hey forma Team
I was wondering if it would be possible to add rotation of the contained image inside the geoJson
Hey forma Team
Hey,
can you please add some example screenshot to explain what you mean?
@samarvir_singh_bhayana
Yes let me explain in more details,
The goal is when the user downloads a terrain image from inside our extension (which we render as a texture inside Forma Canvas) they will ideally have an option to download said image as a Library Item (terrain image) and use it independently from our extension.
As we render the Image from inside the extension however we slightly rotate the image to place it correctly to the area bounds.
But as we create the geoJson so we can create the Library Item we need a way to also add the rotation we need - otherwise the image will be placed slightly of
Could I somehow add a rotation to the geoJson before adding it as Library Item
Hey @iklimis
You can apply the rotation by multiplying your positions/coordinates matrix by a transformation matrix, there's a library called gl-matrix that can help with that.
Let me know if you have any further questions.
yes @syed_ammar_abbas_naqvi
Can you please elaborate?
my problem is that i need to rotate the image contained inside a geojson
although I can rotate the geojson itself the image that fills the geojson always has the same orientation resulting something in this picture
You see the problem
Thank you
Hey @iklimis
I see the problem now 🙂
To rotate the image and the geojson together you can provide a transform matrix when adding your element to the proposal.
Link to docs
Here is an example where the rotated image result ends up something like this.
Forma.proposal.addElement({
urn,
transform: [
0.9339075179317857, -0.35751468214674925, 0, 0,
0.35751468214674925, 0.9339075179317857, 0, 0, 0, 0, 1, 0,
96.5774229255095, -95.94896547481207, -0.04881836450415927, 1,
Hope this helps, let me know if you have any further questions.
Hello again and thanks for your answer
The problem is that I do not intent to use the addElement() method because I would like to let the user import the Library element and import it when they choose
Meaning I just use thecreateItem() to create the GeoJson and add it the Library
when the user imports the geojson however the geojson must appear with rotation
Any updates on this one?
hey @iklimis
That makes sense, let me share a solution that would work for having the rotated image in the library.
I have this example here:
const geojson = {
type: "FeatureCollection",
features: [
type: "Feature",
properties: {
fill: {
imgUrl:
"https://letsenhance.io/static/73136da51c245e80edc6ccfe44888a99/1015f/MainBefore.jpg",
opacity: 1,
color: "#ffffff",
geometry: {
coordinates: [
[-294.9588054623455, -288.804088331759],
[331.04119453777093, -288.804088331759],
[331.04119453777093, 370.1959116663784],
[-294.9588054623455, 370.1959116663784],
type: "Polygon",
const { blobId } = await Forma.integrateElements.uploadFile({
authcontext: "authcontext",
data: JSON.stringify(geojson),
const { urn } = await Forma.integrateElements.createElementV2({
properties: {
category: "referenceImage",
noiseIgnore: false,
treatAsVegetationInWindAnalysis: false,
virtual: true,
referenceImageLink: null,
color: "#755252",
opacity: 0.6,
representations: {
terrainShape: {
blobId,
type: "linked",
footprint: {
blobId,
type: "linked",
const { urn: urn2 } = await Forma.integrateElements.createElementV2({
children: [
urn: urn,
transform: [
const item = await Forma.library.createItem({
data: { name: "My new item", status: "success", urn: urn2 },
What I am doing in this example is creating an element with the image, and then creating a parent element for the image element which has a transform for rotating the image. and then storing the parent element with the transform and image to the library.
Hello again @syed_ammar_abbas_naqvi
I tried this solution and although the rotation problem might be solved there is an issue when the user imports the image form the Library
Instead of the image being placed according to the coords of the geojson the image is not being placed it just hovers over the area and the user has to manually place it by clicking somewhere
That presents a problem because the user cannot center or place the image precisely - the image has to be georeferenced in order for the terrain to be concise with the area
we do not want the user to place the image - the image must be placed according to the coordinates
Hi again @iklimis
That makes sense. I feel like we are addressing only the symptoms here and not the real underlying problem. Do you mind me asking why do we need the image to be rotated? I have a feeling there's a deeper issue here about conversion from lat/long to UTM and the true North not aligning correctly.
From the video in your latest reply, it seems like even if we were to manage to successfully rotate and geolocate the image correctly, it will not achieve the purpose of a basemap correctly fitting and covering the whole terrain, which I am assuming you would like to do.
If possible we can schedule a meeting with one of the engineers who worked on making the image ordering pipeline inside Forma and try to discuss a solution that addresses the core problem.
Let me know if I am making any incorrect assumptions or if you have any further questions.
Send me an email at ammar.naqvi@autodesk.com with what call times usually work for you and I will schedule a call to look into this problem.
Ammar
Hey!
You can now try the new terrainTexture representation when creating the element.
const imageElement = {
"properties": {
"name": "my-image.png",
"category": "referenceImage",
"geoReference": {
"srid": 32631,
"refPoint": [
450951.58389586565,
5418912.06353131
"representations": {
"terrainTexture": {
"type": "linked",
"blobId": upload_link["blobId"],
"properties": {
"mimeType": "image/png",
"opacity": 1,
"color": "#ffffff",
"boundingBox":
0,
-500
500,
0
0,
500
-500,
0
0,
-500
const { urn } = await Forma.integrateElements.createElementV2(imageElement)
The boundingBox property can be rotated and should work properly.
Hallvard
Hey @hallvard.braatenE6H3T
thanks for implementing this
so, just to make sure:
I still need to use the uploadFile() method with a geojson or an image of the integrateElements Api correct?
So I can use the blobId that is being returned and I can subsequently use it in this line
That is correct! Also, this will only work for images. For other data types you still do it the old way.
would you be so kind as to give me an example of an image File upload?
I tried something like this but with no result
sure! Using ArrayBuffer instead of Base64 string will work.
const response = await fetch(imageUrl);
const blob = await response.blob();
const arrayBuffer = await blob.arrayBuffer();
const file = { data: arrayBuffer}
const { blobId } = await Forma.integrateElements.uploadFile(file)
