Error: Unable to access this data. You are not currently logged in
dgual
dgual
Forma in Rhino is currently give me this error: Unable to access this data. You are not currently logged in. I can visualize the data by i does not let me bake it into rhino. How can i do to bake the information from forma to Rhino?
greg_marr
@dgual What version of the Plug-in are you using?  You can see this information at the bottom of the panel.  Did you upgrade to 0.7.6 in the last day or so?  If so, did this just start after that upgrade?  If not, can you try upgrading to that version and see if it still happens?
Also, this forum is for software developers working with the Forma API.  This really belongs in the Forma Forum at https://forums.autodesk.com/t5/forma-forum/bd-p/6140
Greg from Forma
dgual
using version 0.7.6 I will post it again to the other forum
