FlexSim Knowledge Base
Announcements, articles, and guides to help you take your simulations to the next level.
Autodesk Interoperability FlexSim Module Now Available
Autodesk has released a module that provides better functionality between FlexSim and Autodesk software. FlexSim users can download the module by navigating to the “3rd Party Modules” tab on the FlexSim downloads page:
Downloads - FlexSim Account
Please note that the module will work with FlexSim version 24.2.2 or later.
The first release of the module includes the following:
  • Added support for loading ipt, iam, and rvt files.
  • Added a new AutoCAD FlexScript API.
  • Updated dwg importer using the Mesh API.
More information about the module can be found in the user manual here:
User Manual - ADSK Interop
Instructions and examples of how to use the module can be found here:
Autodesk Interop Module Example Models
You can find a demo of the new features (10:10 - 29:55) in the Autodesk University class recording here:
Elevating Factory Design: FlexSim and the Future of Autodesk Fusion Digital Factory
If you need to report a bug, please make a post in the Bug Report space. If you have a new idea for the software, please make a suggestion in the Development space.
Comments
Hi Parker,
after installing this Module, when AutoCAD is imported into FlexSim as background, a few bugs are found as following:
1. unit scale issue. My AutoCAD unit is millimeter, but units convert (from millimeter to meter) in FlexSim is invalid.
2. line color and text of AutoCAD disappears in FlexSim.
@Walker huang
Can you email me the drawing file or attach it in a private post? We can then try to replicate these issues and see what we can do to resolve.
Hi Parker,
how could I send drawing file to you?
Sorry @Walker huang, I forgot to include my email address in the first reply. Please send to [email protected].
The release notes for Adskinterop 25.2 fails to declare that it only works with Autodesk titles (Vault, Navisworks, AutoCAD, Inventor, Vault) 2026, and if those titles must be installed BEFORE installing Adskinterop.
Paul, do you know that they must be installed before or you are asking the question?
Because I have that same question.
@paul.philpott @patrickABAWF
Autodesk products do not need to be installed before the Adskinterop module, they can be installed afterwards.
To utilize the full FDU functionality available in 25.2, for instance, to open a layout in Inventor or AutoCAD that was created in FlexSim, you will need the 2026 version of FDU and associated products.
We will update the documentation to reflect this information.
