LMTOOLS not serving license
joaquin_macanas
joaquin_macanas
Hello all,
I've migrated my license server to a new virtual machine and I'm having problems to get the license served to the client laptops. I've properly installed the LMTOOLS and got the license with the flexsimserveractutil.exe app. And also created the rules for firewall. When I run the log of LMTOOLS what I get is the following:
17:17:21 (lmgrd) -----------------------------------------------
17:17:21 (lmgrd)   Please Note:
17:17:21 (lmgrd)
17:17:21 (lmgrd)   This log is intended for debug purposes only.
17:17:21 (lmgrd)   In order to capture accurate license
17:17:21 (lmgrd)   usage data into an organized repository,
17:17:21 (lmgrd)   please enable report logging. Use Flexera's
17:17:21 (lmgrd)   software license administration  solution,
17:17:21 (lmgrd)   FlexNet Manager, to  readily gain visibility
17:17:21 (lmgrd)   into license usage data and to create
17:17:21 (lmgrd)   insightful reports on critical information like
17:17:21 (lmgrd)   license availability and usage. FlexNet Manager
17:17:21 (lmgrd)   can be fully automated to run these reports on
17:17:21 (lmgrd)   schedule and can be used to track license
17:17:21 (lmgrd)   servers and usage across a heterogeneous
17:17:21 (lmgrd)   network of servers including Windows NT, Linux
17:17:21 (lmgrd)   and UNIX.
17:17:21 (lmgrd)
17:17:21 (lmgrd)
17:17:21 (lmgrd)
17:17:21 (lmgrd) Server's System Date and Time: Thu Nov 06 2025 17:17:21 Romance Standard Time
17:17:21 (lmgrd) pid 1808
17:17:21 (lmgrd) Changing message security level from -1 to 0
17:17:21 (lmgrd) SLOG: Summary LOG statistics is enabled.
17:17:21 (lmgrd) Done rereading
17:17:21 (lmgrd) FlexNet Licensing (v11.19.8.0 build 295082 x64_n6) started on ESVLCVDT0026 (IBM PC) (11/6/2025)
17:17:21 (lmgrd) Copyright (c) 1988-2025 Flexera. All Rights Reserved.
17:17:21 (lmgrd) World Wide Web:  http://www.flexerasoftware.com
17:17:21 (lmgrd) License file(s): C:\FlexSim_LMTOOLS\flexsim.lic
17:17:21 (lmgrd) lmgrd tcp-port 26914
17:17:21 (lmgrd) (@lmgrd-SLOG@) ===============================================
17:17:21 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
17:17:21 (lmgrd) (@lmgrd-SLOG@) Start-Date: Thu Nov 06 2025 17:17:21 Romance Standard Time
17:17:21 (lmgrd) (@lmgrd-SLOG@) PID: 1808
17:17:21 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.19.8.0 build 295082 x64_n6 ( build 295082 (ipv6))
17:17:21 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
17:17:21 (lmgrd) (@lmgrd-SLOG@) Listening port: 26914
17:17:21 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
17:17:21 (lmgrd) (@lmgrd-SLOG@) Is LS run as a service: Yes
17:17:21 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
17:17:21 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c C:\FlexSim_LMTOOLS\flexsim.lic -l C:\FlexSim_LMTOOLS\log.log -z -s
17:17:21 (lmgrd) (@lmgrd-SLOG@) License file(s) used:  C:\FlexSim_LMTOOLS\flexsim.lic
17:17:21 (lmgrd) SLOG: FNPLS-INTERNAL-VL1-40000
17:17:21 (lmgrd) Starting vendor daemons ...
17:17:21 (lmgrd) Starting vendor daemon at port 56914
17:17:21 (lmgrd) Using vendor daemon port 56914 specified in license file
17:17:22 (lmgrd) Started flexsim (pid 3716)
17:17:24 (flexsim) FlexNet Licensing version v11.19.8.0 build 295082 x64_n6
17:17:24 (flexsim) SLOG: Summary LOG statistics is enabled.
17:17:24 (flexsim) SLOG: FNPLS-INTERNAL-CKPT1
17:17:24 (flexsim) SLOG: VM Status: 1
17:17:24 (flexsim) SLOG: FNPLS-INTERNAL-CKPT5
17:17:24 (flexsim) SLOG: TPM Status: 2
17:17:24 (flexsim) SLOG: FNPLS-INTERNAL-CKPT6
17:17:24 (flexsim) Using options file: "C:\FlexSim_LMTOOLS\flexsim.opt"
17:17:26 (flexsim) Server started on ESVLCVDT0026 for:	serverfeature
17:17:26 (flexsim) commercialuse	compile		consolescript
17:17:26 (flexsim) createobjects	dragdropconnect entiretree
17:17:26 (flexsim) expertfit	nomodellimit	stochastics
17:17:26 (flexsim) xmlsaveload
17:17:26 (flexsim) EXTERNAL FILTERS are OFF
17:17:26 (flexsim) ALL FEATURES: INACTIVITY TIMEOUT set to 900 seconds
17:17:26 (lmgrd) flexsim using TCP-port 56914
17:17:26 (flexsim) Changing message security level from -1 to 0
17:17:26 (flexsim) SLOG: Statistics Log Frequency is 240 minute(s).
17:17:26 (flexsim) SLOG: TS update poll inte
rval is 600 seconds.
17:17:26 (flexsim) SLOG: Activation borrow reclaim percentage is 0.
17:17:26 (flexsim) (@flexsim-SLOG@) ===============================================
17:17:26 (flexsim) (@flexsim-SLOG@) === Vendor Daemon ===
17:17:26 (flexsim) (@flexsim-SLOG@) Vendor daemon: flexsim
17:17:26 (flexsim) (@flexsim-SLOG@) Start-Date: Thu Nov 06 2025 17:17:26 Romance Standard Time
17:17:26 (flexsim) (@flexsim-SLOG@) PID: 3716
17:17:26 (flexsim) (@flexsim-SLOG@) VD Version: v11.19.8.0 build 295082 x64_n6 ( build 295082 (ipv6))
17:17:26 (flexsim) (@flexsim-SLOG@) === Startup/Restart Info ===
17:17:26 (flexsim) (@flexsim-SLOG@) Options file used: C:\FlexSim_LMTOOLS\flexsim.opt
17:17:26 (flexsim) (@flexsim-SLOG@) Is vendor daemon a CVD: No
17:17:26 (flexsim) (@flexsim-SLOG@) Is FlexNet Licensing Service installed and compatible: Yes
17:17:26 (flexsim) (@flexsim-SLOG@) FlexNet Licensing Service Version: 11.19.8.0
17:17:26 (flexsim) (@flexsim-SLOG@) Is TS accessed: Yes
17:17:26 (flexsim) (@flexsim-SLOG@) TS access time: Thu Nov 06 2025 17:17:24 Romance Standard Time
17:17:26 (flexsim) (@flexsim-SLOG@) Number of VD restarts since LS startup: 0
17:17:26 (flexsim) (@flexsim-SLOG@) === Network Info ===
17:17:26 (flexsim) (@flexsim-SLOG@) Listening port: 56914
17:17:26 (flexsim) (@flexsim-SLOG@) Daemon select timeout (in seconds): 1
17:17:26 (flexsim) (@flexsim-SLOG@) === Host Info ===
17:17:26 (flexsim) (@flexsim-SLOG@) Host used in license file: ESVLCVDT0026
17:17:26 (flexsim) (@flexsim-SLOG@) HostID node-locked in license file: NA
17:17:26 (flexsim) (@flexsim-SLOG@) HostID of the License Server: 00505681996b
17:17:26 (flexsim) (@flexsim-SLOG@) Running on Hypervisor: VMWare
17:17:26 (flexsim) Ecomms: Encrypted Communication disabled
17:17:26 (flexsim) TCP_NODELAY NOT enabled
17:17:26 (flexsim) Listener Thread: running
17:17:26 (flexsim) Starting diagnostics port (./.logger) listener thread (DPLT)
17:17:26 (flexsim) Starting diagnostics output thread (DRQT)
17:17:26 (flexsim) DPLT: running
17:17:26 (flexsim) DRQT: running
17:17:27 (flexsim) DPLT: waiting for logger to connect
According to above output, everything seems to be normal, like in manual. The VM is perfectly reachable from my laptop, can connect even remotely and so. But for some reason that I don't get, when I open FlexSim in my laptop with the concurrent server license defined on that server (either only ESVLCVDT0026 or 26914@ESVLCVDT0026).  It never gets the license delivered.
In the old server it was working with lmadmin, but as lmtools is recommended, we have changed to this. But firewalls and permissions are the same in both machines. Only difference is that this new machines is Win11 and older is Win10.
Any idea on the root of the problem?
Thanks in advance.
wangyangWTKKN
You can refer to this post and then make sure to use the updated "flexsimserveractutil" program to activate the software authorization.
https://forums.autodesk.com/t5/flexsim-knowledge-base/license-server-flexnet-licensing-service-64/ta...
Ben_WilsonADSK
Hi @joaquin_macanas ,
Indeed, it appears from your log file that all is in good order for the license server hosting your licenses properly. Please verify connectivity between your client PC and your license server using the "Advanced connectivity - ports test" information found here:
License Server - Client/Server connectivity - Autodesk Community
Use the same license server naming scheme you are trying to use in your software. So in your case:
Test-NetConnection ESVLCVDT0026 -Port 26914
Test-NetConnection ESVLCVDT0026 -Port 56914
If that does not work, try a more exact server name or address. You may need to add more parts to your license server name, like (just an example - contact your network engineers to find the real network scheme!):
ESVLCVDT0026.mycompany.corp
If you still are not getting a connection, double check the firewall exceptions. If you opened the ports 26914 and 56914, you may want to also allow the executables lmgrd.exe and flexsim.exe as described here ("Allow an app through Windows Firewall"):
lmtools - Add Windows Firewall exceptions - Autodesk Community
If you previously allowed the executables, that should be enough, but for a belt-and-suspenders approach you could also specifically open ports 26914 and 56914 (though I've never seen that be necessary if you allowed the apps through the firewall).
You may also check that the version of the license activated on your license server is the same as or greater than the version of software running on your client PC. For instance, if your license server is hosting FlexSim 25.1 licenses, but you are starting FlexSim 25.2 on your client PC, the client software will not be licensed.
Let us know what you find. Good luck.
joaquin_macanas
Hello @Ben_WilsonADSK and @wangyangWTKKN ,
It seemed some kind of confict on the services. Since we had both installed the LMTOOLS and the lmAdmin. We did a clean reinstall of LMTOOLS and deleted rest of things and seems to be working fine now. Thans for the fast reply on both of you.
