Show only
Search instead for
Import another model option inside standard Flexsim
Perhaps, could be possible to implement the feature that Flexsim HC has "Import Another Model" inside the standard Flexsim to import in a smooth way differents parts of one system.
Right now there isn't a simple option to click, like in FlexSim HC. However, if you need to do this right away, there is a manual way to do it.
In the model tree click on Tools under the model node, then hit enter to open a new folder at the bottom. Right-click the new node and go into Node>Load into Node.
In the search bar search for .fsm files and import your other model.
After importing, you'll want to shift-select the new model nodes from under flypath, then go to View in the top menu and click Edit Selected Objects. Click on the very top model node, then on the right window click Move into Model.
After this you may need to delete duplicated objects, move packed media around, or transfer variables or global tables to fully merge the two models.
Flexsim has got the ability already. It is called modules and belongs to the SDK in github. You are looking just for an easier way to integrate sub models. But that could be a mistake, because the interdependent functionality can cause unexpected behaviors. For example you use a global user variable in two different ways, how to integrate this in the central model? How to merge this?
Select the entities which you want to export in to the another model from treenode and use 'Ctrl C' to copy and 'Ctrl V' to paste in another flexsim model's treenode.
