Export FlexSim Layout to CAD (dimensions and 2D drawing) in order to use as a documentation for real layout update
The idea is after the models layouts analysis generate an output layout, (similar to CAD *.dwg) with dimensions and 2D drawing in order to use as a documentation to move the factory equipment (change the real layout) according to the FlexSim simulation model layout definition.
Maybe we can eliminate the rework for update the final layout drawing at autocad.
3 Comments
manikantaravi22
Have you found any way to do this
jfzz111
Same question。 How ?
You can now export a USD stage for import to other tools or possibly even join a live session from both applications.
