Allow pulling to token.Object.Label
Not sure if this is an idea or a bug report, but I expected this to work already and just found out it doesn't.
When I want to pull to a token label, I can enter "token.Destination" in the Pull To field and the label will be created if it didn't exist before.
However, if I want to have an indirection here, it doesn't work: if the token already has a label "token.Object" which points at something supporting labels, and I try to Pull To "token.Object.Destination" I will get
time: 0.000000 exception: FlexScript exception: Label property pulled retrieved on /Box1. Label does not exist. at MODEL:/Tools/ProcessFlow/ProcessFlow/Pull from List>variables/assignTo
Instead, I need to write the more verbose token.Object.labels.assert("Destination").
pull_to_object_label.fsm
1 Comment
logan_gold
I know this is a few years old now, but I did want to mention something for anybody that sees this idea.  I believe this is expected behavior.  If you look at the documentation for the Assign To property, it mentions the need to use something like the assert() example mentioned in the original post.  This is still the case today with FlexSim 25.1.
