Webserver IIS problem with Model Directory
nilP8GEZ
nilP8GEZ
[ FlexSim 24.2.1 ]
I need help with the WebServer. At first, the installation worked perfectly, and I could access the models without any problems. But after following the steps to use IIS, when I try to check which models are available, none show up.
I have reviewed the entire procedure to make sure everything is correct, and when I open FlexsimWeb, the login panel appears where I can enter my username and password. However, once inside the Web Server view, the model dropdown is empty.
I have checked to make sure it's not an issue with folder access permissions, but I haven't been able to fix it (everyone has permission).
Does anyone have any idea what I could do?
Thank you very much.
jason_lightfootVL7B4
You may need to add iuser to the folder permissions - I'm a little bit hazy on this as it's a long time since I set it up for IIS.
nilP8GEZ
Thanks, Jason. We set access permissions for all users, but it doesn’t work. Do you know what else it could be?
Ben_WilsonADSK
If this is the latest IIS on Win 11, the slashes aren't handled correctly. Please see Paul's Answer here.
Paul mentions you could use either Apache or Nginx as a proxy instead of IIS until a fix is released that addresses this issue.
I would take a look at this link about securing resources for IIS access.
Also check your path to the model folder in the configuration text file in the inetpub folder - if the path is correct I wonder if you can change the slash type between fwd/back in case that works.
logan_gold
Hi @Nil Ns, was Ben Wilson's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
