Global Table treenode question
yjhung_mcae_fcu
yjhung_mcae_fcu
[ FlexSim 24.2.1 ]
Hi, I discovered an issue when adding a Global Table. When opening the Tree, only the first row displays the name of Col1, but the second row does not. Additionally, when clicking on "use bundle" in the Global Table, both rows appear, but the original Row1 name is changed to "1." I'm not sure if this should be considered a bug.
yjhung_mcae_fcu
I have entered the license code. If it doesn't show up, please let me know, and I'll provide it again.
jason_lightfoot_adsk
That's how they were designed - only the top row was originally needed for the column names. The top row is no longer needed with the current global tables - when you remove all rows, the columns are cached under the global table object's attributes. If you're using non-global table node the columns will still need to be written on the first row. The displayed value for the bundle is just an numeric since you cannot key off a row name and instead must using the index or supply your own field based key.
logan_gold
Hi @我才是馬邦德 , was Jason Lightfoot's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
