Walk to object does not completely work for rotated object
patrick_zweekhorst
patrick_zweekhorst
[ FlexSim 20.1.1 ]
When you give a person a travel task to a rotated BasicFr it does not travel to the correct location:
The man stops walking at the point shown in the picture. Is this by design and should we solve that ourselves or is this a bug? The man actually walk to the location where the BasicFr would have been if it was not rotated.
WalkToLocExample.fsm
Matthew_Gillespie
This isn't happening because the object is rotated, it's because you're object is much longer in one dimension. When a Task Executer travels to an object it takes the longest dimension of the object and uses that as the diameter of a circle that goes around the object. When the TE reaches that circle then they stop their travel task.
This isn't a bug, this is how FlexSim has always worked. Depending on what you're doing in the model you can have the person walk closer to the object using a Travel to Loc activity or a Load/Unload activity.
Matthew Gillespie
FlexSim Software Developer
patrick_zweekhorst
Hi @Matthew Gillespie,
Thank you for clarifying this. We did expect a circle, but around the TE, not the object. But you explanation makes sense.
