Wait For Event - Exception on Reset
thomas_smithWKC4J
thomas_smithWKC4J
[ FlexSim 23.0.1 ]
I have a subflow that acquires multiple resources. It will only acquire resources if all are available, otherwise it will wait for resource availability to change.
When I reset my model, if there are tokens still in the Wait For Event blocks, an exception will be thrown. There doesn't seem to be any negative consequences of it, but I would like this to not happen.
A few years ago I had modified a version of the simultaneous list pulls (https://answers.flexsim.com/questions/98195/simultaneous-all-or-nothing-list-pulls.html?childToView=...) using resources, and had the same problem. However, it seemed to disappear one day. Now that I am creating a different version of this, this bug is happening again.
To recreate, reset the model when there are tokens still in a Wait For Event. It should be as simple as a couple Skips and a Reset.
Any thoughts?
Acquire Multiple - FS Answers Version.fsm
jason_lightfootVL7B4
I do not observe the exceptions you describe - can you try this in 23.0.4 ?
thomas_smithWKC4J
Weirdly enough the mystery error is gone after installing 23.0.4.
This was the same problem (and possibly, solution) as I had experienced two years ago. Not sure why that would be the case twice separate times, but for my purposes the problem is solved. Thank you
