How to build and animate a customized AGV with capacity >1?
donghuangliUNJR4
donghuangliUNJR4
[ FlexSim 22.2.2 ]
Hi, I am building a customized AGV with capacity of 2.I want to animate the AGV as a simple rectangular shape and put the loaded items in parallel. With the default setting, the items are stacked. Please see the figure below:
Do you have any ideas? Thanks.
joerg_vogel_HsH
@Donghuang L3 , you know there is a search tool. You can try such word combinations like agv stacking, agv packaging, agv set location, agv item placement. This question has been discussed since 2016 at this site. I think I answered it maybe last time about 3 month ago to copy code from item bin tool of a packaging method to an on entry event of an agv. So I think I gave you some ideas, don’t you think, too?
joerg_vogel_HsH
donghuangliUNJR4
Thanks! I found the solution I need by searching the keywords you recommend.
