Use different load animation based on flowitem
jacob_edge6FHXZ
jacob_edge6FHXZ
[ FlexSim 21.0.6 ]
I have an operator that has to push carts, and also load material into a machine. Is there a simple way to change the load animation (and location of the flowitem relative to the operator) depending on the flowitem the operator is carrying?
Above are the 2 animations I would like. I am able to change to one or the other, but I'm not sure how to incorporate both using one operator. I would prefer to avoid using code if possible. I'm fairly proficient with process flow if that is the only other option. Below is what I currently have. Change Visuals on Load.fsm
FelixMoehlmann
You might be able to do it with the "Run Animation" process flow activity, but using code (only a single line) is probably much easier. You can listen to the On Entry trigger of the operator with an Event triggered source in process flow. Depending on some condition (item label/size/etc) the token is send down different paths and does two things:
1. Set the "walkLoadedAnimation" variable of the operator to change which animation is used if the operator has loaded something. The animation Names are the same you woud set in the operator's properties.
object.setVariable("walkLoadedAnimation", "animationName");
2. Change the position of the item inside the operator (if necessary)
I'll attach an example model where this is done for two different item sizes; one being carried, the other one pushed.
ChangeWalkAnimation_21_0.fsm
jacob_edge6FHXZ
Thank you so much @Felix Möhlmann! This is exactly what I was looking for.
