[ FlexSim 21.2.4 ]
Hi everyone. Working with control points (AGV) I have noticed that the 'allocation event’ is executed at different moments/locations (not necessarily in the previous 'control point') when the TaskExecuter speed is increased in AGV network properties. This only happens when both straight and curved speeds are changed (≥2) and the deceleration is kept at 1.
As both speeds are increased (keeping the deceleration at 1) the 'allocated' event is executed earlier. The attached model shows the mentioned situation.
That being said, is there a relationship between the control point’s 'allocation event’ and the speed/deceleration properties of the TaskExecuter? Are there speed/deceleration limitations in the use of the AGV network?
Thanks in advance for the help
