[ FlexSim 21.2.3 ]
When using FlexSim on a customer's machine, all interactions are smooth except with the library left pane.
Here is an illustration in the gif below:
- 3D view: smooth
- dashboard view: smooth
- properties right panel: smooth
- 3D library left pane: high latency
- Dashboard library left pane: high latency
- Process Flow library left pane: high latency
- Code library left pane: smooth
Would you have a hint why the library left pane has latency when displaying 3D objects, dashboard charts, Process Flow activites but not when it displays the code library ?
Here are the specs on the machine used:
