- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
[ FlexSim 20.1.3 ]
I have a layout where from one trigger event to make 3 agvs start at the same time. I have succeeded to make 3 agvs start, but when the agvs arrives at each queue to load, first token works ok, but the other tokens remain at "pull from list" activity as you can see in below capture. If you check "Run each token at a time " in the subflow, it works. Where do I need to correct the problem?
