Transporter moves between two different routes based on logic
talia_z
talia_z
[ FlexSim 17.2.5 ]
Hello! My aim is to have Transporter1 transport pallets from "Unload truck" separator to the "Bottles" queue, as well as transport pallets from "WH_Caps" queue to the "Caps" queue. The transporter should check to see if "Caps" >0 and, in this case, the transporter should move the pallets from the "Unload truck" separator to "Bottles". If this queue is not >0, the transporter should transport pallets from "WH_Caps" to "Caps". I am having trouble establishing this logic - thank you in advance for your help!
bottle-unloader-process-v2.fsm
tanner_p
I noticed that the pallets with the red boxes on them were moving themselves to the "Bottles" queue because of the separator's flow logic. I added a queue at the separator for these pallets to wait at until Transporter1 can come move them.
Here's a version of your model using Process Flow. The idea is that there is one token that will acquire Transporter1 each loop. It will first decide whether "Caps" content > 0.
Transporter1, now accessed as "token.transporter", will then load at one of the locations you outlined.
Lastly, it will unload where you designated, return the resource, and start the loop again.
I hope this helps! If you have any questions or adjustments you'd like to make, let me know.
Model: bottle-unloader-logic-pf.fsm
talia_z
This is very helpful - thank you so much!
