Train change direction at start
MarcoBaccalaro
Message 1 of 1
MarcoBaccalaro
we are facing many problems in trying to change direction of a train.
There is a bug in the train coupling that calculates the wrong gap between the locomotive and the first trailer. We solved it by changing the size of the new locomotive before the coupling and restoring it after the coupling. (Attaching and detaching trailers instead of using uncoupling and coupling didn't work as well).
This patch works, but the following problem is really strange.
I have attached two models. One is working, one not.
The only difference is that a block of activities is done in a process flow rather than another.
In the not working model, the Train 1 process flow holds the block of activities (highlighted in the following screenshot):
In the working one, the only difference is that this block of activities is moved into the subflow:
How is this possible?
Thank you.
Replies (0)
