sum value in array
sum value in array
jason_p2
sum value in array
jason_p2
[ FlexSim 19.2.3 ]
I have a token for each warehouse order. I need to get the total quantity per order, so I need to sum up the array token.Qty. How do I create a label that sums the array for example token.OrderQty = 11
regan_blackett
You could copy this and paste it into the Code Editor for the Value field on an Assign Labels activity:
Array theArray = token.Qty;
double aggregate;
for(int i = 1; i <= theArray.length; i++)
    aggregate += theArray;
return aggregate;
joerg_vogel_HsH
By a table query over the array length with a SUM clause
Array qty = [12,1.23,3.56];
double sum = Table.query("SELECT SUM($2) FROM $1",
      			    /*$1*/ qty.length,
      			    /*$2*/ qty[$iter(1)]
  			)[1][1];
print(sum);
rcsrcs31
I know this comment is a bit old, but I was wondering if you could explain further in detail the following part of the logic:
FROM $1
/*$1*/ qty.length,
 I do not fully understand how you can you read from an integer. I tried to go through the documentation, but I wasn't able to fully understand it.
Kind regards.
joerg_vogel_HsH
Table .query("SELECT 'something' AS a_thing FROM $1",4).cloneTo(Table("myTable"));
results in myTable of four rows containing each cell a string of something. Header is a_thing.
$iter is Flexsim SQL Clause to iterate over each discrete structure from 1 to last element. If it is an integer like 4 then it is 1,2,3,4.
Please look for first given answers here at this forum about the keyword 'iter'.
See also Advanced Query Techniques in Manual.
