Time Plot generates a single point instead of continuous line.
gudapatisriharisha
gudapatisriharisha
[ FlexSim 22.2.0 ]
I am trying to create a time plot for the first row values of the table. Value vs Time ( as highlighted in the global table). The values in the cell are changing dynamically and I want to plot that change over time. However, there is only a single dot that is being generated and a line isn't generated inspite of the draw style option in the properties of the plot being "Line". I changed the Time value to date and time format and yet it doesn't work. The time value in the global table is a discrete number. ( generated by the "CURRENT_DAY" command).
moehlmann_fe
A Calculated Table doesn't store values. It only contains the current result of the query.
You need to use a Statistics Collector instead. Which in this case you don't have to build yourself, necessarily. Change the table cell into a Tracked Variable.
Then link it to a Tracked Variable Line Chart
gudapatisriharisha
Hello Felix,
Thank you. I shall try this and see if it works.
gudapatisriharisha
Hello, It still doesn't plot the graph inspite of assigning the datatype as tracked variables.
moehlmann_fe
Can you upload your model or share screenshots of the table and chart settings?
gudapatisriharisha
Hey Felix,
Sorry, I cant share the model due to my work. But, I just tried another way. I copied the dynamic cell values to another global table and created a statistics collector table to do the time plot. It works for now, not sure for future scenarios. Thank you for helping! 🙂
logan_gold
Hi @Sri, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
