Time Plot generates a single point instead of continuous line.
gudapatisriharisha
gudapatisriharisha
[ FlexSim 22.2.0 ]
I am trying to create a time plot for the first row values of the table. Value vs Time ( as highlighted in the global table). The values in the cell are changing dynamically and I want to plot that change over time. However, there is only a single dot that is being generated and a line isn't generated inspite of the draw style option in the properties of the plot being "Line". I changed the Time value to date and time format and yet it doesn't work. The time value in the global table is a discrete number. ( generated by the "CURRENT_DAY" command).
FelixMoehlmann
A Calculated Table doesn't store values. It only contains the current result of the query.
You need to use a Statistics Collector instead. Which in this case you don't have to build yourself, necessarily. Change the table cell into a Tracked Variable.
Then link it to a Tracked Variable Line Chart
gudapatisriharisha
Hello Felix,
Thank you. I shall try this and see if it works.
gudapatisriharisha
Hello, It still doesn't plot the graph inspite of assigning the datatype as tracked variables.
FelixMoehlmann
Can you upload your model or share screenshots of the table and chart settings?
gudapatisriharisha
Hey Felix,
Sorry, I cant share the model due to my work. But, I just tried another way. I copied the dynamic cell values to another global table and created a statistics collector table to do the time plot. It works for now, not sure for future scenarios. Thank you for helping! 🙂
logan_gold
Hi @Sri, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
