The condition "a conveyor is empty and a queue is empty" in "Decide" activity ?
sara_s2
sara_s2
How to set the condition "a conveyor is empty and a queue is empty" in "Decide" activity ?
(FlexSim version 19.0.0)
Regards.
tanner_p
Object MyConveyor = Model.find("Conveyor"); //Change to name of Conveyor
Object MyQueue = Model.find("Queue"); //Change to name of Queue
if(MyConveyor.subnodes.length == 0 && MyQueue.subnodes.length == 0)  {
  return 1;
tanner_p
The key, of course, is the portion in the "IF" statement if you're using the Conditional Decide pick list option.
sara_s2
Thank you very much for your help.
Is there a difference if I use directly Model.find("conveyor") instead of defining the object Myconveyor ?
tanner_p
That works just fine as well. I defined it so it looked cleaner in the code, but you can define it however you'd like, even with a label.
