ASRSvehicle tasks priority.
sara_s2
sara_s2
"ASRSvehicle1792" in figure1 performs three tasks: loading totes from "Queue2154", loading totes from "Queue1798" and loading totes from "Rack1788". In order to make those tasks priority equal to 1, 2 and 3 respectively, I set priority = 1.00 for the first task (figure2), priority = 2.00 for the second task (figure3) but for the third task I didn't set any priority (figure4) because it is managed by the process flow "ProcessFlowCW".
Would this allow to execute the three tasks in the mentioned order without fixing a priority of the third task?
(FlexSim version 19.0.0)
Regards.
tanner_p
The Process Flow also allows you to set a priority. The Create Task Sequence activity has a variable for Priority. I recommend setting this up in your Process Flow so that as the ASRS vehicle receives tasks from the 3D logic and Process Flow, it completes them in the correct order.
sara_s2
@tanner.p, thank you for your help.
