Strange behavior in using AStar bridge
sebastian_hemmannE3JAU
[ FlexSim 25.1.1 ]
It seems that using a bridge in AStar makes problems with routing the operators or other Task Executers.
The operator stops at the end of the bridge object. If 2 operators are on the path the same time, they are jumping around.
I attache the model but only used default options so far.
AStar_Bridge_Problem_FlexSim25.1_SH.fsm
Update 2025-08-29: Does anybody from the development team read this?
kavika_faleumu
Hey @sebastian_hemmannE3JAU, I've added this issue to the dev list.
I'm sorry, the dev team doesn't monitor the forums very closely. The forums have become more of a "community driven" space. If you'd like more prompt replies to bug fixes and such, I recommend going through the support team's ticketing system. That's how they primarily handle cases now, focusing on users that are up to date on licensing.
Hope this helps.
