Array.sort() Error
Array.sort() Error
ozawa_shinya
Array.sort() Error
ozawa_shinya
[ FlexSim 24.0.9 ]
I would like to sort the data in a Map class by key, so I converted the Map to an Array and use the sort() method of Array, but it hangs in 2024 but ran without any problems in 2025. What is the difference in this behavior?
For each model, when you run the script after fast forwarding, it will hang in 24.0.9 version, but there will be no problem in 25.0.6 version.
https://answers.flexsim.com/articles/164649/heatmap-anything.html
heatmapAnythingTest24.0.9.fsm
heatmapAnythingTest25.0.6.fsm
Thanks in advance.
kavika_faleumu
Hey @ozawa_shinya, yes there was a fix with Array.sort() sometime between 24.0 and 25.0. I'm glad that it runs without issue in 25.0+.
