Socket Question
Socket Question
hsiangchao
Socket Question
hsiangchao
[ FlexSim 23.1.2 ]
I'm trying connect 3 clients to socket. These are my steps. You can see it connect successfully in step 2.Then I send message in step3 but server only receive message from socket 1, socket 2 and socket 3 doesn't receive. It's any wrong with my script? Thank's.socket-1.pngsocket-2.png
natalie_white
Hi @Sean!
In your first script, you just need to add two more lines of code that say "serveraccept(0)". This is because serveraccept() can only accept a single client connection, so you need to run the command three times.
If the socket indices have not been reset, you may need to check your server side connection numbers and your client side connection numbers to make sure they are correct in order for this to work.
