Export Global table from Experimenter runs
ssrdh
ssrdh
[ FlexSim 22.2.4 ]
Attacted is a simple model using queues and operators.
experiment.fsm
I have setup an experimenter with 20 replications. I want to export the global table "Delta_record" for each replication to an excel file consisting of 2 columns.
Column 1: ReplicationID
Column 2: Delta (value from global table in model).
Is it possible to do it?
moehlmann_fe
I would suggest to copy the global table to a Calculated Table. The data will then be part of the experiment results stored in the sqlite file.
It can then be exported from the results window.
experiment_1.fsm
