Sequential Ramp Processing in FlexSim
begum_aydemirM7H9M
Message 1 of 1
begum_aydemirM7H9M
In the simulation, there are two ramps connected to the red dispatcher. From each ramp, three types of products are unloaded: totes, pallets, and boxes. The operator teams can serve both ramps jointly.
However, at time 0 seconds, products may arrive at both ramps simultaneously. In the example scenario, totes arrive at both ramps at the same time.
In the real-life operation, this situation is handled differently:
  • First, all products from one ramp are completely unloaded.
  • Only after finishing that ramp, operators move to the other ramp and unload all its products.
In other words:
  • Products should not be picked simultaneously from both combiners (e.g., “Çuval14” and “Çuval16” at the same time).
  • This rule applies to all product types (totes, pallets, and boxes).
Expected Behavior
What I want to achieve in the simulation is:
  1. Operators should fully complete unloading one ramp.
  2. Only after that, they should move to the second ramp.
  3. Then, they should complete unloading the second ramp.
Issue
I have tried multiple coding approaches, but I could not achieve this behavior.
I have attached the model below.
Could you please demonstrate the solution directly on the simulation?
This is an issue I have been working on for a long time.
Thank you in advance for your support.
Replies (0)
