Objects not appearing in 3D view
huang_anice
huang_anice
Hi to all,
When I clicked the objects, the model never showed the figures which I chose.
I don't know the reason and how do I set up in the FlexSim ?
Thanks a lot.
sam_stubbsYXX86
It looks like the Source Object you created is there, but it appears as though you are zoomed out very far. If you scroll in with your mouse wheel, the Source should become more visible. Is that what you are asking?
jeff_nordgren
@Huang Anice
It may be that you need to update your video drivers on your computer. You should also check the Minimum System Requirements on our website to make sure that your computer is capable of running FlexSim.
