Conditional Port
Conditional Port
manocher_djassemi
Conditional Port
manocher_djassemi
@Ben Wilson
I am using conditional port in a Separator. I have entered:
content(node("Rack1", model())) <=30
If True Port 1 If False Port 2
The Separator is connected to Rack1 (port 1) and a queue (port 2).
When I run the model, all items flow to Rack1, none goes to queue even when <=30 condition is met as can be observed. Any solution will be appreciated.
Manocher
cameron_pluim
If the Rack is connected to outport 1, you could use the following:
if(content(outobject(current,1)) <= 30) {
	return 1;
} else {
	return 2;
Ben_WilsonADSK
@Manocher Djassemi,
That code should have worked, assuming your rack is named "Rack1".
Can you attach your model?
manocher_djassemi
That solved the problem. Thanks
manocher_djassemi
I am using the following codes in Flow tab of a Separator. Port 1,2,and 3 are connected to 3 racks.
While the first IF condition sends item 9 to port 2, the second one does not send the item 8 to port 3. It keep sending it to port 1. I ran the model long enough to make sure the condition >=5 is met. Is there anything wrong with these codes? Thanks
if(content(outobject(current,1)) >= 5&&getitemtype(item)==9) {
return 2;
if(content(outobject(current,1)) >= 5&&getitemtype(item)==8) {
return 3;
} else {
return 1;
