Invalid down cast error
sudheer_r
sudheer_r
[ FlexSim 23.2.0 ]
ACR_9.fsm
I am getting below error. Any feedback on this error type
arunTTT2P
Battery label is not created as a tracked variable type, so you have to convert it as a tracked variable type (kinetic) and the label dischargeRate is not present on the ACRs.
sudheer_r
I have changed Battery to tracked variable
Still below error is occurring
Attached the model for reference
ACR_9.fsm
moehlmann_fe
As Arun said, you have to set it as a kinetic Tracked Variable to be able to set a rate.
sudheer_r
Yeah Its working now
mischa_spelt
You may have a sign error still. If current.dischargeRateLoaded is positive, then you probably want to set the Tracked Variable rate to -1 * current.dischargeRateLoaded . If it is negative, the tracked variable rate is correct but the time calculation to empty needs to be multiplied by -1.
