How to use the XML-related functions provided by the flexsim script help
royjuventus29
royjuventus29
[ FlexSim 22.2.4 ]
Hello, I have found out that there are some XML functions in the help documentation of flexsim. such as below, I have put them into my script, but it generates an error as it cannot be recognized during the debugging, do I need to declare something at the beginning of my script? Thank you!
XML.Document doc = XML.loadFile("test.xml");
XML.Element root = doc.root;
XML.Element element = root.first;
JordanLJohnson
My guess is you need to specify an absolute path to the file you want to open. If the xml file is in the same directory as the model, I would use the modeldir() command:
XML.Document doc = XML.loadFile(modeldir() + "test.xml");
Jordan Johnson
Principal Software Engineer
royjuventus29
Thank you for your answer. I already used the absolute path, and the error is "Unknown type XML.Document in declaration of variable doc". It seems the software does not understand the meaning of "XML.Document". Do you know how to make the function understood by the software?
jason_lightfoot_adsk
The XML API was only added in version 23.1.
royjuventus29
Yes, you are right, this is a matter of software version. Thank you very much!
