- Mute
- Permalink
- Report
[ FlexSim 18.2.2 ]
I have the following Global Table being used to provide cycle times for my processors.
The Row name is the name of the processor.
I pull the Cycle Time using the standard "Global Lookup Table" procedure:
Object current = ownerobject(c);
Object item = param(1);
/***popup:GlobalTableLookupNew*/
/***tag:Description*//**Using Global Lookup Table ( CycleTimes )*/
Variant tableID = /**\nTable: *//***tag:TableName*//**/"CycleTimes"/**/;
Table table;
switch (tableID.type) {
case VAR_TYPE_NODE: table = tableID; break;
case VAR_TYPE_STRING: table = Table(tableID.as(string)); break;
default:
table = reftable(tableID.as(int));
break;
Variant row = /**\nRow: *//***tag:row*//**/current.name/**/;
Variant col = /**\nColumn: *//***tag:col*//**/"CycleTime"/**/;
return table[row][col];
Is there a more efficient/elegant way to pass the processor name into the getstream() without hardcoding the processor name value? Thanks.
