- Mute
- Permalink
- Report
[ FlexSim 18.2.2 ]
I have the following Global Table being used to provide cycle times for my processors.
The Row name is the name of the processor.
I pull the Cycle Time using the standard "Global Lookup Table" procedure:
Object current = ownerobject(c); Object item = param(1); /***popup:GlobalTableLookupNew*/ /***tag:Description*//**Using Global Lookup Table ( CycleTimes )*/ Variant tableID = /**\nTable: *//***tag:TableName*//**/"CycleTimes"/**/; Table table; switch (tableID.type) { case VAR_TYPE_NODE: table = tableID; break; case VAR_TYPE_STRING: table = Table(tableID.as(string)); break; default: table = reftable(tableID.as(int)); break; } Variant row = /**\nRow: *//***tag:row*//**/current.name/**/; Variant col = /**\nColumn: *//***tag:col*//**/"CycleTime"/**/; return table[row][col];
Is there a more efficient/elegant way to pass the processor name into the getstream() without hardcoding the processor name value? Thanks.
