How to modify the custom code of queue output panel?
j08j
j08j
[ FlexSim 24.0.2 ]
I want to modify the custom code of queue output panel "Use Transport".screenshot-2024-04-11-at-35427-pm.png
There is my code:screenshot-2024-04-11-at-35405-pm.png
It can only checked the box of "Use Transport", but it still maintains the default settings "current.centerObjects[1]".
How can I deal with this problem?
Thanks.
moehlmann_fe
Where did you get "UseTransport.TransportResource" as a property name from? The actual property name would be "TransportRef" (as you can see in a property table), though using that also doesn't work, since setting this property toggles the node to not be flexscript anymore.
Use Queue.setVariable("transportdispatcher", ...) instead.
j08j
Thanks for your reply and help!
