Problem importing opc ua variables
BPassos01
BPassos01
[ FlexSim 22.0.16 ]
Recently i've been working with OPC UA and having the need to import variables to work with the process flow. Although, I'm having problems importing 5 or more variables, crashing the FlexSim. Does anyone know how can I import a large amount of variables without having problems with the simulation or malfunctioning of the software?
Thanks in advance!
jason_lightfootVL7B4
Can you check that it works with UAExpert to eliminate configuration/network issues? At what point does it crash? We also recommend you use the latest bugfix versions (for which you'll also need an Emulation module license).
michael_machado
@Breno Bogéa your company is using the limited version of the Emulation module and the old one. The full and most recent emulation module is acquired separately from FlexSim Enterprise. If you need any quotation regarding the Emulation Module, please e-mail vendas@flexsimbrasil.com.br
lcavallero
With the latest version of the emulation module our customers work regulary with more than 100 UPC tags.
Latest version contains OPC UA protocols optimizations and bug fixing that make OPC UA more reliable. I suggest to move to latest version as @Michael Machado suggested.
